Thanks for your help.
I have now used the image 2.20.8 and flash. I have restarted the Reach RTK and open the app. (Because this is where I expect to be able to press update)
I have attached a screenshoot from the app (ipad), but it keeps asking me to do the firmware update, as you can see in the picture.
I have now flashed the dev. to the Reach RTK. but one “accident” does not come alone!
After the new flash, will it not connect to my wifi! (It worked fine before)
I have now tried to connect it 10 times, either by configuring it in the app or browser.
So i cannot get access to the internet, and there by not update… ?
You can connect to Reach hotspot?
Do you have the antenna connected?
Does it help if you have the antenna i somewhat clear sky to let it sync
If you add :5000 at the end of the IP adresse, what do you get?
Edit: One more thing, is your Wifi handing out IP addresse in the range of 192.168.2.xxx ?
If so, try share wifi with your phone and let Reach connect there instead
If your Reach is not connected to internet, it will not inform you of updates.
The reach create a hotspot, that I can access. So this works fine.
I connect to it over :5000 and configure the wifi I want it to access, and press connect. It then close it own hotspot for a while (2min), but then it opens it own hotspot again.
I’m using my iPhone as hotspot and it hands out IP: 172.20.10.x on subnet 255.255.255.240
Yes, the antenna is connected.
No, right now i’m indoors, but this worked fine in the non-dev. firmware.
And you have tried turning the power off for Reach for few minutes and then on again after wifi has been added?
On your phones, do you see it connect before it drops the connection?
You have tripple checked the password is correct typed in?
Try changing wifi password to something different and simpler
