Hello everyone!
I hope you are well.
I am currently working with a Raspberry Pi 4 and ROS Noetic to perform autonomous navigation. However, I’ve been having trouble trying to install the dependencies needed for this.
I found a thread where they shared a script that seems to help install these dependencies:
Apparently, I was able to install all the dependencies, but I’m having trouble with one called “navigation”. When I check the /opt/ros/lib folder, all the other dependencies are installed except this one. This is causing an error when I try to perform my catkin build on my workspace.
I have followed the steps in the above thread, but it looks like I might be making an error when running the code that installs this dependency. According to the attached thread, the command would look something like this:
bash install-ROS-packages.sh “navigation”
I would appreciate any help or suggestions you can offer, thank you very much!
@svetlana.nikolenko
