I am only saying the problem is not between the USB adapter and the PI. It could be anything up to the USB adapter.
Also, if you want to adjust the baud rate, you can do that by specifying it like so:
stty -F /dev/ttyS0 57600
Could you narrow the problem though through that troubleshooting?
Yes, what we learned is that:
You must decide what else has been eliminated as a potential problem, see what parts are still suspect to have a problem, and then test those parts of the communication link.
I did not go back to review what you learned with Marcās advice, but you should review what parts you know to work and what you donāt; then continue testing or asking how to test.
I think I should order another telemetry module as it is obvious that the air telemetry station is not receiving any data from the ground station although it seems that their lights are solid. What is your suggestion?
Before ordering, try to use the telemetry modules between two computers and exchange text via Xterm or equivalent application. When happy with your settings and familiar with the modules and serial interface, test again the mavlink connection.
Cool, will do that God willing,
thanks for the suggestion Marc.
Hey Marc, I canāt really find a good tutorial on the web and havenāt figured how to send a text through telemetry to another computer. Your help will be appreciated.
It (is) was basic āComputer 101ā 30 years ago.
Have a look here https://www.intel.com/content/www/us/en/support/articles/000017881/intel-nuc.html and use your telemetry modules in place of null-modem cable.
Ok I did exactly as followed and opened a putty terminal; however, I couldnāt press āsā or send any data or receive any. There was a yellow light on the USB adapter. What would this mean?
Sorry for the disturbance @bide, I have bought another telemetry and when I run the above command, it outputs
stty: /dev/ttyUSB0: Input/output error
What does this mean? I still am having trouble with connecting the mavLinks to mission planner and have absolutely no idea what could be wrong. Your assistance will be much appreciated.
With regard to the special device file: /dev/ttyUSB0
(where 0 is a number that increments for each device that you plug in)
The general Input/output error you see is because either the special device file is not there, or you donāt have permissions to access it. Both scenarios we covered up above in this post.
If you need further explanation, I will provide it.
I got it working, there was a minor problem. Even though I have bought a new telemetry, the problem still persists, no data coming in through screen and no heartbeat when connecting to mission planner.
So if data is supposed to come through the Telemetry and itās not, what could be the reason other than the telemetry it self. Iām a beginner to tech, if you could help me troubleshoot this, it will be much appreciated bide.
Well, Iām glad you figured it out. But we can only do so much. Help to check your telemetry device should come from the seller or manufacturer, or that forum.
As we mentioned before, you should remove the telemetry device from your project and proove that it works between two computers (or between 2 ports on the same computer).
I think it would be good if you found a local person with sufficient experience to help you with that or to check them for you. The knowledge required is basic and general (for people familiar with computer hardware interfaces).
The problem could be so simple, but you must start with one thing that āworks,ā then add components or complexity one piece at a time until your whole system is operational.
Proove the telemetry first.
All right cool, I will see first that my telemetries work and texts are exchanged, else I will bye telemetries that are directly usb and not require usb adapter.
Thanks, I will get back!
Ok, one of connecter lines was kind of burned during my previous solder, having fixed that, when I now connect to MP I get access denied error. The screenshot is the error, if you know this error, please do help.
@mlebret @bide
Sorry for the ping, I would not have done it if it were not for the fact that I have searched everywhere on the interenet yet found no answer. The above screenshot error of āAccess deniedā is given in Mission planner, and in QGround āCould not create port. Access is deniedā error is given.
If you know anything, please do help.
Much appreciated.
Iām sorry, but I do not now. Hopefully someone else can offer a suggestion.
Hey all, long time. I finally today found the solution after many trials and test. And to my surprise, the telemetries were fine and all the hardware too, the telemetries would get locked but not transfer data. At one time having the telemetries connected, I ran sudo systemctl restart arducopter, and when it restarted the red light started flashing on both telemetries. And when I connected through MP, it connected!!!
So basically, the solution was running that command while the temetries are connected! Long time, but finally found the solution alhamdulillah!
