Hi, Has anyone ever ordered rtk emlid tools for phantom 4 pro on tuffwing? How do I see the order status?
Hi @dicky,
I’m afraid we can’t be of much help with the Tuffwing order. We don’t support any custom solutions to make the GNSS equipment work with DJI products. DJI ecosystem is proprietary and doesn’t allow a straightforward integration.
However, we have created a guide on sending the base corrections from the Reach RS2 base to the DJI Phantom 4 RTK via NTRIP. You can check it out here.
Phantom 4 Pro PPK LED system is working alright. We have used it here in Cambodia.
How about the accuracy?
Few cm off check points
how do you deal with photo capture delay?
The light sensor does a pretty good job, but I did have some isolated cases where it would miss an event. You can put the measurements for the “rover” antenna in RTKLIB. I ended up installing the Vanavara AShot board which eliminates it completely and doesn’t miss events.
http://www.vanavara-digital.com/collection/frontpage/product/ashot
