I was trying to update a reach RS from ReachView 2.0 to the current ReachView 2.5 and during the update process the internet feed was interrupted. Not when I boot the Reach RS, I get 3 solid LEDs ( Orange, Blue, Green). The RS is not connecting to the network anymore and is not creating it’s own hotspot. I’ve tried a hard reboot with the result still being 3 solid LEDs and no network. This to me indicated the need to reflash, with the goal being to load ReachImage 2.3.
However I can’t get the Reach RS to register with the Edison flashing tool, ie it says there is no edison device connected and times out. I’ve installed the drivers multiple times. I’ve tried to flash on 2 separate windows machines with the same result. I tried the command line flashing but get stuck at needing the xfstk tool - which I understand needs a linux.
Hello, one of the devices reach rs (in my case the base) stopped from one moment to another to allow access after the last update, does not identify any device and the times that has been Reflash with firmware the led of the team are left : Red and Green (static) blue (intermittent).
I have weeks trying to solve this and nothing.
I have tried several versions, currently I managed to install the version v.2.9 after several failed attempts to install the 2.14
Exactly Reach RS is flashing blue and Orange / Green lights up permanently.
is a Reach RS unit
Are you able to post a screenshot where your throuble starts?
Also a screenshot of your status screen and/or by logging on to Reach
by IP address and then add :5000 . E.g xxx.xxx.xxx.xxx:5000 (where x= ip address to your Reach RS unit)
