New to all this and have been fighting with my files trying to get something processed - no luck yet!
But I have my Trimble R9 Base station static data to use with my reach rover (Drone)
The Trimbles base files are in a .T02 format.
I have converted the t02 file using the Trimble utility - “Convert to Rinex”
After conversion I get 3 files:
######.18g
######.18n
######.18o
Do I have to run the .18o file through RTKCONV so the extension changes to .obs?
As well, is there anything I need to do with the .18n file so it becomes a .nav?
I figured as much, but im just grasping at straws here.
im following the instructions down to the T, yet when I hit plot, theres nothing there.
I have ran every single file I have hoping that i miss read something or that the instructions where bad.
Let me know if that works.
There will be a folder in there called drone file, it will have the raw .obs and the formatted version of it, with the event38 format utility tool.
The other 2 files are the my base station
Your base and rover time are different and don’t overlap. That’s why you don’t get a solution.
On top of that I don’t think RTKlib likes the base. The rover antenna also seems weak. Only 1 sat is over 45 db, the rest 35 or lower.
It plotted, but when you have a Q=5 solution, it means no use of the base file, you could just as well have processed the rover file as Single. You will get the same results.
They’ve tried to be helpful when someone was available.
Would had been nice to originally get a screen share or something going for a walk-through.
Id imagine there had been others that bought their craft having zero experience with PPK.
The instructions on their site are a bit… sparse in areas
