Topcon Magnet Field Issues
10-4. 10hz is not glonass. I can choose Galileo and SBAS. Trying 14hz gps-only now.
The base can have everything on correct?
Not sure if this matters… but @Brent_W is using (2) RS+ receivers correct? And @michaelL (1) RS+ for BASE and (1) M+ for ROVER correct? Again, not sure that matters, but I just noticed that difference from @Brent_W just in case.
in the end, hope it works out for @michaelL! ; )
It definitely shouldn’t make a difference that I can think of.
I’m using my base and rover right now. I tried 14hz and 10hz both GPS only and then GPS/Galileo/SBAS. I’m out of time right now because I need to go verify hey subcontractor’s benchmark that is busted with my topcon, but I will play with this some more tonight. Hopefully I will have a little bit of time after this benchmark check to try out feel genius.
Maybe it’s in the version of Topcon Magnet Field…
when you get time, to rule that out, what version MAGNET?
I’m on version 5.1.
I’ll try to update my trial version. To me it’s no loss if it quits working.
The 30 day Trial download says v4.3 (20170531)
(MAGNET_Field_Layout_v43_Internet_Assisted_Tethered_20170531)
I haven’t installed yet, but I guess the Trial will connect via internet to UPDATE to maybe whatever the latest version is? (v5.1???)
I can put up the install file if you guys want?
Thanks, we’ve been sharing links to that already! :slight_smile:
Cool, just catching up. This is what I have. Direct installs.
@michaelL Do these install as 30 day trials if no activation etc?
Yes, as long as it is the first install on the device. I believe if Magnet was there before it might just start in demo mode. Fully functional, but only let you shoot so many points.
