I am not using Topcon Magnet Field yet (have not installed yet), but using FieldGenius 9/10 on a similar older style data collector Trimble Nomad 900G. So “typically” when using a straight up serial cable such as the Emlid one you and I have, serial port connection is TYPICALLY COM1. My Bluetooth works just fine, so going to stick with it. I purchased the Emlid serial cable as a back up in case of trouble.
I haven’t tried using the serial cable on my Surface Pro yet. I have a serial to USB converter, but I don’t have the need to mess with that yet. I also have some big projects coming up, so like Chasco, I don’t want to mess anything up that is working fine right now.
Wise choice Chasco, I wouldn’t go connecting anything either until you know for certain the pinouts are correct if not using a genuine Emlid cable.
Thanks for the warnings! There is much to be learned… This cable is from emlid but I suppose it still applies.
Also, FYI I used to connect my surface pro 3 via USB. USB to pc.
yes, I do that too and with Bluetooth. But in order to use your Emlid Serial cable the Surface Pro does not have the old style serial port connector (some and older laptops do), so you would need an additional serial to USB converter. That was just added info in case anyone needed to do that for whatever reason, but really, might as well use Micro-USB to USB or BT, unless they really need to use a Emlid sertial cable to a PC without old serial port.
if you have either the Emlid cables with connectors on BOTH ends, I think you’ll be fine, but just habit of mine:
I do not have the connector-less on one end version, but from what I understand (I am NOT certain) this is the one for people that also need POWER in addition to just the data communication:
The cables with the connector only have 3 wires connected internally. Ground, TX, and RX. They can take +/- 25 Volts, so it is highly unlikely you could hurt your Reach RS+ if the pins got mixed up. Of course, this doesn’t mean I am taking responsibility Do your homework first.
@michaelL Were you ever to get your TOPCON MAGNET data collector / software to work via Bluetooth using the settings @Brent_W used that worked for him?
I changed my update to 1hz and the same thing. In reachview I had 27 satellites for the base and the rover, but the magnet software only show 21 base and 12 rover. I went back into settings and change the shot requirements from dgps to all and no dice. One difference though is that now that is showing 21 base and no Rover, but it is fixed. Which view shows 26 for both.
