Timestamp cannot be converted
Here is the attaced file showing me error time stamp cannot be converted please me in that.https://drive.google.com/file/d/1axLxfaQLgzh8JoYrVCCFqSZ_3LRMrgRO/view?usp=sharing
Hi Mubashir,
I see that you are sending an email to support. I am checking the data and will let you know.
Hi merryna, have you check the data?
Waiting :pensive::pensive::pensive::pensive:
Hi Mubashir,
I did reply to you via email. Have you received it? If not, there might be an issue with the sending process. Let me know!
I checked the data. The stop-and-go is not processed in Emlid Flow since it isn’t been downloaded from Emlid Flow. I also attached the example of the CSV file to the email. It’s not possible to do it here, but here is the header and the order:
Name,Code,Easting,Northing,Elevation,Description,Longitude,Latitude,Ellipsoidal height,Origin,Easting RMS,Northing RMS,Elevation RMS,Lateral RMS,Antenna height,Antenna height units,Solution status,Averaging start,Averaging end,Samples,PDOP,GDOP,Base easting,Base northing,Base elevation,Base longitude,Base latitude,Base ellipsoidal height,Baseline,Mount point,CS name,GPS Satellites,GLONASS Satellites,Galileo Satellites,BeiDou Satellites,QZSS Satellites
Thanks for your cooperation
2 posts were split to a new topic: Timestamp can’t be converted in Stop&Go
