Could someone please clarify whether this has been implemented in the mean time or how I can implement that myself? Or has someone e.g. @vclor implemented it and would share the solution?
I would also be interested whether there is a delay introduced by mirroring.
Thank you, I think I mixed up Time pulse and PPS. PPS is basically a time pulse per second, with a rising edge at very full second (23:59:59.000), right?
I think I can work with PPS, my goal is to sync inputs from different sensors with the gnss data.
Could that program mentioned below be written in Python and would that program be fast enough to introduce no delay?
Is their a developer guide some where?
Some information I have collected from the forum which gives hints but leaves a lot of questions and I would be interested to have more/clarified information about it.
Is that PPS or configurable time pulse?
I.e. it could be mirrored on GPIO46 or GPIO77?
Where is the confusion (M8T pins, or Edison pins and naming in hardware and software?) and where can I read about that?
GPIO46, GPIO77, PWM, SCL, SDA, TX, RX are connected to Intel Edison via buffers and are 3.3 V logic level, 5 V tolerant.
SCL and SDA belong to I2C1 on Intel Edison, I2C1 also could be used to communicate with internal magnetometer in MPU9250.
This could be used to output the MPU9250 data or record other sensor data with the Edison?
