I recently acquired an Emlid Reach UAV Mapping kit, including RS+ and M+ units, as well as an Emlid LoRa radio. I have set up the M+ unit on a DJI S900 hexacopter (as shown below) and am using it to log points that I mark via another means as I take pictures with a Canon S100 camera.
However, while I know that the time marks are being recognized by the M+ and pictures are being taken (using a wifi connection to the unit), none of the time marks are coming out of the post-processing procedure for RTKLIB published in your documentation.
I have tested that the M+ does recognize the time marks and is logging GPS data using RTK updates. My RTK settings are as follows:
I am using the copy of RTKLIB available from the Reach documentation (Kinematic processing | Emlid Studio). I should have at least 100 time marks, but I only receive a .pos file with position data (not correlated to time marks) after following the procedure described there. I would attach the log files, but, as a new user, the system will not allow me.
Any help is appreciated, as, after perusing the forum and documentation, I’m at a loss for how to procure a file with time marks and coordinates.
Yes – you understand correctly. There is a .pos file output from RTKLIB, but not with an “__event” tag in the filename.
Let’s try this: http://bit.ly/2MrQA0Y. That link should have the raw and post-processed files. There is a RINEX file in the Rover folder (which came from the M+), but I posted with RTKLIB from the UBX file in case there was something I was missing.
I don’t see time marks in your supplied .OBS file but i can when i convert the UBX file to RINEX myself - 135 of them. Perhaps convert the UBX again with the latest version of rtkconv.exe.
i know you didn’t ask, but i’d log more satellite constellations at a slower rate rather than GPS only. i can’t see the benefit of high Hz logging for UAVs at the expense of more satellites. At 5hz you could log GPS+GAL+GLO. I’m logging GPS+BDS+GAL and all time marks are present. With this I am able to fix some UAV flights with ref station data from >20km away.
I get the feeling that my GLO data has lower quality compared to the GPS data (SNR, cycle slips). I also have data sets where I only can get a solution when skipping the GLO data. I thought that a higher data rate might provide more information and thus help to get a fix quicker/more reliable?
perhaps that isn’t an exhaustive list of stable configurations. I’m going ok with GPS+BDS+GAL. I checked the satellite availability in your area and it looks like that could also be your optimum combination. BDS have more satellites than GAL or GLO and GAL is about the same as GLO for numbers and might be a cleaner signal. That’s just based on my GAL processing residuals usually being pretty clean compared to the other constellations. That is, when GAL is actually online!
I like to imagine stronger geometry, higher number of satellites with differing frequencies would lead to more reliable and faster fixes, but i’ve not tested it too hard. I haven’t had a flight fail to fix with the extended constellation tracking but GPS only has been unreliable in the past. Also having my flights fix over very long baselines suggests to me that multiple constellations @ 5Hz is the way to go for me.
Ah cripe – thank you all for the help. Turns out that, while I had downloaded the Emlid RTKLIB, I was still using the executable for the original RTKLIB. I now have an *__events.pos file with 135 events logged in it.
