I am getting a failure in Test 2 on a Reach M2 unit. What does it mean?
I didn’t perform an upgrade. I Just noticed that the PPS signal was not present, I measured and got 0.6V so I rebooted and now that Test 2 failure is all that I get. It connects to the WiFi network, though.
The current firmware version is 2.24
EDIT:
This is some info from /var/log/reach-ublox-daemon.log
around the time it started to fail:
[2020-11-12 01:16:39.529] [RUD] [info] applySettings: applying...
[2020-11-12 01:16:39.529] [RUD] [info] applySettings: corr_out applying...
[2020-11-12 01:16:39.529] [RUD] [info] applySettings: corr_out: path: 'tcpsvr://:9000'
[2020-11-12 01:16:39.529] [RUD] [info] activateCorrOut: msg_cfg: '1074(1.0),1084(1.0),1006(10.0)'
[2020-11-12 01:16:39.531] [RUD] [info] activateCorrOut: llh_pos: (52.05666396749575 -9.5008459324188 38.71272991452993), ant_hgt: 0.0, path: 'tcpsvr://:9000'
[2020-11-12 01:16:39.535] [RUD] [info] applySettings: success
[2020-11-12 16:24:22.358] [RUD] [error] Mainloop: status info is invalid more than 10268 ms
[2020-11-12 16:24:22.362] [RUD] [info] Receiver configuration: 1
[2020-11-12 16:24:35.336] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:24:36.336] [RUD] [info] Receiver configuration: 2
[2020-11-12 16:24:49.328] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:24:50.329] [RUD] [info] Receiver configuration: 3
[2020-11-12 16:25:03.302] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:25:04.302] [RUD] [error] Receiver configuration: failed
[2020-11-12 16:25:05.304] [RUD] [error] Mainloop: status info is invalid more than 53214 ms
[2020-11-12 16:25:05.304] [RUD] [info] Receiver configuration: 1
[2020-11-12 16:25:18.278] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:25:19.279] [RUD] [info] Receiver configuration: 2
[2020-11-12 16:25:32.252] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:25:33.252] [RUD] [info] Receiver configuration: 3
[2020-11-12 16:25:46.227] [RUD] [error] detectBaudRate: failed to detect baud rate
[2020-11-12 16:25:47.228] [RUD] [error] Receiver configuration: failed
