Can I suggest a section in the Navio Docs about different Gimbal hardware setups? There is the APM general documentation, but it is all pixhawk specific and does not cover 3-Axis Gimbals other than Storm32.
I ran into problems setting up my Feiyu 2axis gimbal also. And documented them here, It’s not very logical but i think you should be able to get it working if you read that post
You’ll have to use rc passthrough function on the RC_X channels you specify (RC_9, RC_8 etc) Pasthrough will mean RC_9 will passthrough your transmitters channel 9 signal.
Where in mission planner (1.3.48) with copter 3.4.6 can i find the “BRD_CAN_ENABLE” and “BRD_SBUS_OUT” assuming they excists for navio2? Atm i just see BRD_SERIAL_NUM in full parameter list.
what is the default output-signal for navio2 output 9-14 (pwm or sbus)? trying to use passthrough on channel 10.
There is no CANbus or SBUS output on the Navio. It basically just passes through what the Raspberry Pi offers with the exception of the RC coprocessor for sbus/ppm input and hardware PWM and also an ADC. Perhaps it will possible to add sbus output with a firmware update for the RC coprocessor. You will have to use PWM to control your gimbal.
ok, can’t get the gimbal moving with pwm (as i’ve read others also had problems with). I know the signal are passed through the navio since it activated some other servo i tested on it. The gimbal wont even work when i connect it directly into the FrSky X8R in mode 4.
I think there is a problem with the firmware version v1.1 on the tarot gimbal. I had tilt working before i updated, and now, with v1.1 nothing works in pwm mode^^
