Static Logging Settings - 1 second setting
I am logging static data but could not find setting to set it to record at 1 second intervals. I have tried 1hz, 5hz but the recording interval is smaller than 1 seconds. In the sample RINEX output below it’s 46.704
1 1
19 8 28 5 54 46.7040000 0 5G19G 6G 2G13G 5
23143238.376 3 -2712.202 25.000
23440293.888 -197.537 28.000 23440289.881
19 8 28 5 54 46.8040000 0 5G19G 6G 2G13G 5
23143289.758 3 -2712.022 25.000
23440297.640 -197.729 28.000 23440293.712
3 -145.353 16.000
23519963.229 1643.978 26.000
Is there a setting that would make the logging file record at 1 second intervals?
I have several other non-emlid units and I would like to know if this will affect post processing results if time intervals are not synchronized ?
The other units are currently in the field so I am not able to do a full test.
Thank you.
Can you post a simple report, when unit is set to 1 hz under RTK Settings?
Sorry, still new to the unit. What is a simple report? Is it the RINEX file? Can’t seem to upload it to the forum. A section of the RINEX file is as follows:
2.10 OBSERVATION DATA M (MIXED) RINEX VERSION / TYPE
*RTKCONV 2.4.3 b33 20190828 060151 UTC PGM / RUN BY / DATE *
*log: D:\Downloads\raw-201908280554-UBX\raw_201908280554.UB COMMENT *
*format: u-blox COMMENT *
  •                                                        MARKER NAME         *
  •                                                        MARKER NUMBER       *
  •                                                        OBSERVER / AGENCY   *
  •                                                        REC # / TYPE / VERS *
  •                                                        ANT # / TYPE        *
  • -3184537.2483 5285497.4364 1608452.2108 APPROX POSITION XYZ *
  •    0.0000        0.0000        0.0000                  ANTENNA: DELTA H/E/N*
  • 1     1                                                WAVELENGTH FACT L1/2*
  • 8    C1    L1    D1    S1    C2    L2    D2    S2      # / TYPES OF OBSERV *
  • 2019 8 28 5 54 46.7040000 GPS TIME OF FIRST OBS *
  • 2019 8 28 5 58 40.6040000 GPS TIME OF LAST OBS *
  •                                                        END OF HEADER       *
  • 19 8 28 5 54 46.7040000 0 5G19G 6G 2G13G 5*
  • 23143238.376 3 -2712.202 25.000 *
  • 23440293.888 -197.537 28.000 23440289.881 *
  •          3       -145.353          16.000  *
  • 23519994.368 1643.217 26.000 *
  • 22843804.708 2827.546 31.000 *
  • 22588429.718 1 -288.989 27.000 *
  • 19 8 28 5 54 46.8040000 0 5G19G 6G 2G13G 5*
  • 23143289.758 3 -2712.022 25.000 *
  • 23440297.640 -197.729 28.000 23440293.712 *
  • 23519963.229 1643.978 26.000 *
  • 22843750.870 2828.501 31.000 *
  • 22588435.238 -289.193 27.000 *
  • 19 8 28 5 54 46.9040000 0 5G19G 6G 2G13G 5*
  • 23143341.398 3 -2713.285 24.000 *
  • 23440301.422 -197.679 28.000 23440297.155 *
  • 23519931.693 1644.512 26.000 *
  • 22843697.022 2826.942 31.000 *
  • 22588440.001 -288.899 27.000 *
  • 19 8 28 5 54 47.0040000 0 5G19G 6G 2G13G 5*
  • 23143393.161 3 -2711.438 24.000 *
  • 23440305.167 -198.076 28.000 23440300.629 *
  •          3       -143.048          16.000  *
  • 23519899.969 1644.309 26.000 *
  • 22843643.270 2828.049 31.000 *
  • 22588445.572 -289.256 27.000*
Nop, it something that can tell us the state of the system, more here: https://docs.emlid.com/reach/common/reachview/settings/
Got this from the simple report button for 10hz
Simple system report
app version: 2.20.7-rs2-rc0-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
    band: bg
    channel: 1
    password: null
  ip: 192.168.42.1
  is_added: true
  is_connected: true
  mac_address: 6C:21:A2:92:9F:E4
  security: wpa-psk
  ssid: reachbase:39:68
  uuid: 660c7a1c-eefc-42e1-915d-20181a224769
base mode:
  base coordinates:
    accumulation: '2'
    antenna offset:
      east: '0'
      north: '0'
      up: '0'
    coordinates:
    - '0'
    - '0'
    - '0'
    format: llh
    mode: single-and-hold
  output:
    enabled: true
    format: rtcm3
    path: tcpsvr://:9000#rtcm3
    type: tcpsvr
  rtcm3 messages:
    '1006':
      enabled: true
      frequency: '0.1'
    '1074':
      enabled: true
      frequency: '1'
    '1084':
      enabled: true
      frequency: '1'
    '1094':
      enabled: false
      frequency: '1'
    '1124':
      enabled: false
      frequency: '1'
bluetooth:
  discoverable: false
  enabled: false
  pin: '***'
correction input:
  input2:
    enabled: false
    format: rtcm3
    path: ttyMFD2:38400:8:n:1:off
    send position to base: 'off'
    type: serial
  input3:
    enabled: false
    format: rtcm3
    path: :9028
    type: tcpsvr
logging:
  base:
    format: RTCM3
    started: false
    version: null
  correction:
    format: RTCM3
    started: true
    version: null
  interval: '24'
  overwrite: true
  raw:
    format: UBX
    started: true
    version: null
  solution:
    format: LLH
    started: false
    version: null
lora:
  air rate: 2.6000000000000001
  frequency: 868000
  output power: 20
position output:
  output1:
    enabled: false
    format: nmea
    path: bluetooth
    type: bluetooth
  output2:
    enabled: false
    format: llh
    path: :9001
    type: tcpsvr
  output3:
    enabled: true
    format: llh
    path: :2014
    type: tcpsvr
  output4:
    enabled: true
    format: llh_ext
    path: :2015
    type: tcpsvr
rtk settings:
  elevation mask angle: '15'
  glonass ar mode: 'off'
  gps ar mode: fix-and-hold
  max horizontal acceleration: '1'
  max vertical acceleration: '1'
  positioning mode: static
  positioning systems:
    compass: false
    galileo: false
    glonass: false
    gps: true
    qzss: false
  snr mask: '35'
  update rate: '10'
10 hz is indeed reflected in the simple report. But you wanted it at 1 hz, right ?
@wizprod Maybe @jjb means that not only does he want 1Hz output, but he also wants the output synchronized exactly at x.000 seconds. e.g. not 46.704, 46.804, … but 46.000, 47.000 …
Something tells me this might not be an easy thing to do…
But maybe the easy hack is just to modify the position output string by truncating the reported time down to the nearest second.
@bide yes, I need to record raw gps data at 1 second intervals synchronized at every 1.000000 seconds not 1.704xxx intervals.
In other GPS units you just set logging intervals at 1,5,10,etc intervals and the resulting RINEX files are recorded at exactly every 1.000000 seconds and not 1.7002 seconds.
Alrighty :smiley:
Well, yeah for that we need some help from @dmitriy.ershov and his team :smiley:, as it is feature request.
Hi Jun,
You can set up the update rate to 1 Hz in the RTK Settings ReachView tab.
May I ask you to clarify why do you need such intervals? Usually, PPP services and PPK software work fine with RINEX data from Reach.
Previous rinex files from other brands have rounded off time intervals - 1,5,10 seconds. First time I have encountered intervals with decimal values. I plan to use rs2 with Sokkia and topcon units via rinex files. I just received the rs2 and have not yet tested it with other units because they are still being used in the field.
Won’t this decimal time intervals affect post processing if other units have rinex time intervals rounded off to nearest seconds?
Thank you very much.
I can’t tell how it reacts with TopCon/Sokkia Rinex, but using CORS data from EUREF (that many times are from Leica gear) have not been a problem at all in RTKPost.
Obviously there will be a very small delay in correction, but there we are talking 10ths of a second, so in reality, nothing.
This shouldn’t be an issue
Thank you for the feedback.
