Is there any utility to split a single RINEX log into several RINEX logs one for each marked occupation? Thanks in advance
Hi Guillermo,
Is the final goal to have separate points calculated for each location? If so, I think the Stop&Go function in Emlid Studio will come in handy for you. Except for the RINEX data, you’ll need to upload a CSV file from ReachView 3. Emlid Studio will use it to determine the collection start and end for each point.
If I didn’t get your application right, please describe the result you want to achieve. I’ll think of the most straightforward workflow.
