2-What is the use of C1 and C2 port
3-I want to trigger camera using Drotag cable , but I want to save trigger event in Reach M2
4- If I connect hotshoe on c2 port will it save trigger event in raw file
1-What is the use of C2 port
2-I want to trigger camera using Drotag cable , but I want to save trigger event in Reach M2
3- If I connect hotshoe on c2 port will it save trigger event in raw file
You can check the pinout scheme for the C2 port here. You can use this port for time marks recording or the time synchronization via PPS output.
To make sure Reach is recording time marks to the raw data log, you need to integrate the receiver with the camera via the hot shoe connector. Then, Reach will record a time mark each time you take a photo. You can trigger the camera with the autopilot.
You can connect the hot shoe cable to the C2 port. The time marks are going to be saved in the raw data log.
