2 posts were split to a new topic: M2 receives NTRIP corrections but stays SINGLE
All multi-band devices can now work only in kinematic GNSS mode. Why? Please return to both metod, you can reset to kinematic on power on for no mistake but manual change for static I use this option. Please returnu to make choince!!!
Welcome to the community @NSNS
Emlid has said that the distinction and setting of “kinematic or static” was/is relevant to single frequency receivers only. With multi-frequency Emlid receivers, it has no effect on the solution, and in some cases has a detrimental effect by not allowing a FIX when the device is set to “static” and is in motion when otherwise it would be Fixed.
Hello everyone!
Today we’ve released Reach Firmware 31.7 for all devices !
Here is the list of fixes:
- Fixed more cases when log start time or duration is incorrect
- Improved stability of corrections input over UHF radio for RS3
Hello everyone!
Today we’ve released Reach Firmware 31.8 for all devices !
- Fixed a bug that caused a lot of small log files to be created instead of a single large log file.
- Improved stability of corrections input over UHF radio for RS3.
