I’m using a navio+(os: emlid-raspbian-20190227.img), APM Planner v2.0.25 on Mac OS for ground control, and wifi connection.
The problem is when I use TCP to connect navio+ to the APM Planner, the link was always disconnected in a few second.
Here is the message shown on the terminal:
$ sudo arducopter -A tcp:0.0.0.0:14550
Raspberry Pi 2 Model B Rev 1.1. (intern: 2)
MS5611 found on bus 1 address 0x77
MPU: temp reset IMU[0] 4921 0
Interrupted: Segmentation fault
For UDP, this situation also happened:
$ sudo arducopter -A udp:192.168.0.106:14550
MPU: temp reset IMU[0] 4944 3493
