Hello
I came across this topic in the forums ArcGIS Survey123 integration
This method doesn’t work with RX. Is there any way to make S123 and QC work with RX?
Thanks
Hello
Thanks
Hi @Y_Chau,
Position streaming with Reach RX is possible only via Bluetooth. If your surveying software can accept the streamed position this way, the setup should work fine.
One more note: it works only on Android and Windows devices.
Esri Survey123 and QuickCapture don’t find RX when searching for Bluetooth devices. Just to be clear, its not that RX doesn’t work with these apps, but it completely fails to appear in Bluetooth search inside these apps. While it works perfectly fine with another Esri app called Field Maps.
Any guesses what could be the reason?
Thanks
Hi @Y_Chau,
I see. Previously, we tested Reach RX with Survey123, and we could establish the connection using the Lefebure NTRIP client application. Can you please check if it works this way for you?
We haven’t tested QuickCapture with Reach RX yet, but it’s also worth trying with the Lefebure app.
Please feel free to share any further experience!
