Hello, what difference does this RTKLIB QT have with the previous version for RTKLIB EMLID 64bit ???
regards
Hi Gabriel,
The RTKLib version 2.4.3 Emlid b33 makes possible both single- and multi-frequency processing in one software. We also fixed a few minor issues reported by users and made some performance improvements.
Dear @tatiana.andreeva When I finish doing a post process in RTKPOST-QT and I want to see the result with Plot RTKPLOT-QT opens but without the solution (no solutions)???
there is a problem there, the same thing happens to me
Hi Gabriel, Luis,
Thanks for the report! Weāll address it.
May I ask you to clarify whether you work with Windows or Linux build?
we work with the version for windows
Hi Tatiana Windows 64 bits
Hey guys,
Let me update you on this. Weāre still working on fixing this issue with RTKPlot opening empty files. Iāll inform you once weāve fixed it.
Thanks
Thanks Polina
Hello, Tatiana.
Is there any āofficialā doccument that reports these implementations?
It could be good to cite on a scientific paperā¦
Hi Fabio,
Would you mind elaborating on what you mean by the official document? You can find all information about RTKLib functionality and options in RTKLib manual and on the RTKLib website.
Hello. What I mean is about the fact that EMLIDās QT implementation did this: āThe RTKLib version 2.4.3 Emlid b33 makes possible both single- and multi-frequency processing in one software. We also fixed a few minor issues reported by users and made some performance improvements.ā
Is there a report what has been done? What are the differences?! It could be nice to be cited on a scientific article, when using the EMLIDāS implementation!
I agree, a news post with the chances just like with the versions update for ReachView
I noticed at glanse that the Settings2 changed some configs compared to 2.4.3 b28.
When i noticed the change i made a post process from a point that i was comparing with other users in this post and i saw a 30 cm difference from the same post process using version b28, using the exact same configs.
I just started using RTKlib QT. After post-proccesing, when the POS file is generated I see less information than previous version RTKlib demo5 b31.
Is this information not present in Rtklib QT anymore? :
That info is useful when I compare post proccesing archives with different elev masks or other configurable options (GLO on, GLO off, Fix and Hold/Continuous).
EDIT: Solution: Under Optionsā> Output ā> Proccesing Options ā> ON
Hey there,
Weāll consider creating a report with the significant changes made to the RTKLib. Iām afraid that at the moment, I canāt share any specifics.
