In comparing the differences between the old RTKLib(RTKPOST ver.2.4.3 Emlid b27) and the new 64bit one(RTKPOST ver.2.4.3 Emlid b28) I see that dispite the same parameters being used for each, the coordinate mysteriously changes in the 64bit version. Any one seen this? the INI files are identical.
I could be âout to lunchâ here, but were people not complaining about that ref pos field not being reported properly and something was going to be changed to fix it? Maybe this is the change?!?
I have got the same problem using 64bit rtkpost 2.4.3 Emlid b28.
It seems to me that the 64bit version doesnât use the âLat/Lon/Heightâ information from âSettings/Position/Base Stationâ and rather takes the âApprox. Position XYZâ of the base RINEX file instead.
I did a test survey lately and used a VRS to setup a Reach as a base. Then surveyed some points with my 2nd Reach with live-correction from the Base-Reach. I also surveyed the same points using VRS. The measurements are within about 3 centimeters.
Afterwards I did a PPK and all my PPK positions differ from the RTK ones.
I found out the Base-Station Position in the PPK solution file didnât match the VRS surveyed base coordinates. So I compared the âApprox. Position XYZâ of the base RINEX file with the âref positionâ of the PPK solution file and they matched.
Just did another PPK run where I changed the âApprox Position XYZâ of the base RINEX to the VRS surveyed coordinates and the solution is spot on with the base-rover and VRS survey.
But I was still using âLat/Lon/Heightâ as selected option in âSettings/Positions/Base Stationâ ⌠didnât change anything there.
So rtkpost 2.4.3 Emlid b28 aint using the âLat/Lon/Heightâ information ⌠itâs using the âApprox Position XYZâ of the base RINEX instead, while âLat/Lon/Heightâ is selected in the rtkpost options.
And about that âSouthern thingâ ⌠I am from Austria
