RS3 receive corrections but stay on single using external radio with UHF
Hello, we just received the RS3 and are testing the UHF radio with some external radios, we use two radios on this first test and with both of them the RS3 shows on the panel that it’s receiving, but stay on single solution. On the Emlid flow app shows that it’s not receiving corrections.
What could be the problem?
The configs are listed below:
Base: Emlid reach RS2+
Conection with radio: Serial RS232
Baud rate: 19200
Radios
  1. Jicb smart radio
    model:
    baud rate: 19200
    Protocol: Trimtalk T450
    Air data rate: 9600
    Frequency: 441,000 mhz
    Bandwidth: 25.0khz
  2. Pacific Crest
    Model: PDL
    Baud rate: 19200
    Air data rate: 9600
    Frequency: 441,00 mhz
    Bandwidth: 25.0khz
Rover: Emlid Reach RS3
Input correction : UHF
Air data rate: 9600
Bandwidth: 25.0khz
Hi Douglas,
Welcome to the forum!
  • Can you share a photo of your setup?
  • What is the baseline of your survey?
  • Can you get a Fix solution over LoRa radio?
Please also record the following logs for at least 10-15 minutes:
  • Rover log
  • Base correction log
  • Navigation files from both base and rover
You can send this information privately to us at support@emlid.com.
