Yes, they are the RTK solutions, but they will represent the same that you saw at the field. If you had a difference when doing RTK, there will be the same difference on the solution LLH.
You can try “Point Extractor”. It´s a software created from a user that allows you to records points with Reachview and then after post-processing the rinex files from rover-base, extract the coordinates from each point:
https://community.emlid.com/t/ppk-point-extractor-software/12822
Download rinex logs from base and RS2. Use rtkpost to post procces and then use Point Extractor to get the coordinates for the points. Use the official coordinates for the base (permanent station) you are using.
