RS2/RS2+ LoRa Antenna
Are these identical?
I pair my RS2 with my RS2+
Recently the LoRa radio range seems shorter than when I just got the RS2+
I’m wondering if interchanging the antennae could have an effect on the range.
The antennas are the same, however you may be on a frequency with a lot of congestion if you aren’t getting your normal range. You could try adjusting your frequency until you get adequate range.
Hi Adrian,
As Pat mentioned, the antennas you are using are the same both with RS2 and RS2+. I also recommend checking our Support tip to make sure that everything’s set properly.
Okay
Thanks for the link
