I have an issue exporting a survey project .csv file. The issue happens with several projects which I’m making changes to, and have previously exported. After making changes (adding a point or deleting a point in the ReachView app), the subsequent export does not reflect the changes. Although in the ReachView app I can see the changes made, the export file I’m getting looks like the previous export and does not reflect those recent changes.
I’ve tried:
deleting previous exports from the iPhone/iPad
restarting the reachview app
restarting the RS2
not saving to the iPhone/iPad, but rather airdropping to my MacBook
I’m using:
ReachView v2.22.4
iOS 13.5 (iPhone and iPad)
EMLID Reach RS2 (how do I find firmware version?)
system report available, not sure how to include it here…
My suspicions as to the problem:
iOS is not deleting the old exported files, and is not overwriting them when exported from ReachView with the same file name, so I’m seeing old cached files
ReachView app is not exporting current saved data
Update:
I’ve experienced the issue a few times, and I believe a few times have found that after the RS2 unit sits powered off for a little while, overnight for instance, and the export is tried again subsequently, it then does export the correct data… Is there a certain amount of time it takes for the RS2 once powered off to purge cached data or save current projects?
Thanks for the detailed summary. Would it be possible to attach the screen-recording of the issue? You can upload it on any of the file exchangers like WeTransfer or Google Drive and post the link here.
Please share the Full System Report with me in PM as it may contain sensitive information. You can upload the Full System Report in the same way.
We’re still working on fixing this export issue. Meanwhile, you can work with the browser version of the ReachView 2 and with the ReachView 3 beta version.
Just wanted to tell you that we’ve released a new stable v2.24.0 firmware version. It should fix the project export issue that you’ve experienced. You can find the full list of all fixes and improvements of the new version in this community forum thread.
It’d be great if you could update your receivers and share your experience with the update.
Thanks!
