Hi there!
Here is my “short” list of wanted features to enhance my awesome RS2:
- UTM coordinate support
- Custom geoid support for orthometric height conversion
- Satellite imagery basemap
- Additional field for each point to add a custom code (see Florian’s message above)
- One tap instant survey point recording (currently, you need 2 taps: “Collect” then "Save&Go"and it takes minimum 1 second of observation)
- Physical button support (eg: ability to record a point with the volume key of the phone/tablet or with an headset volume button)
- Strict Precision/DOP filter : not being able to record a point if desired accuracy is not met without an obvious alert pop-up message and a warning sound.
- Filter to prevent recording point if not in FIX mode (excluding any SINGLE or FLOAT recordings)
- Bigger status indicator (SINGLE/FLOAT/FIX) when surveying. For example, the background of the Status section in Reach viex could change color (Red/Orange/Green).
- Mini SNR chart (similar to the one in “Status”) in the “Survey” interface. This chart is very useful to know if we have a good satellite view (in real time) when recording points, more visual than a DOP or Sigma/RMS value.
- Quick access to reset all connexion (NTRIP and sattelite), without needing to reset the device (which takes time…). Just to get a new catch of satellite and correction input without the need to put the pole and receiver upside down.
- Edition of a point name, description, antenna height, and add more measurements to it
- Edition of a project settings and name
- USB export of projects and logs (to USB drive or to computer)
- IGS absolute calibration of the antenna for precise PPK (.atx file)
- Create “event” file when recording points. This is useful for post processing the rover Rinex with RTKPost on a computer and automatically extract the points from the POS output file.
That’s all for now
Keep up the good work !
