For 6 years I had Leica GG03 and handunit CS-10!
It always connected via bluetooth, never WIFI, that can be disturbed by other wifi,like it is now with RS2!
Bluetooth is more or less on the same frequency band (as classic WiFi, 2.4 ghz), and will be disturbed just as much as WiFi, if there is are enough interference.
Rs2 still connects to FG via bluetooth.
Huh? Emlid Reach products connect to data collectors mostly by Bluetooth or serial connector to get NMEA data stream… not WIFI.
You use WIFI to connect to the Reach product using ReachView to get to the product’s settings. Which can also be turned off after doing so to save battery.
A post was split to a new topic: ReachView updating
