EBE111057
(Bryan Enfinger)
July 14, 2021, 11:55pm
7
Be careful in multi-path areas with any GNSS receiver. Unless you have some method of verifying the point, you’re taking a big chance in relying on the RTK solution.
Case in point
Why can’t I log longer than 6 minutes in Reachview 3, V6.0 app ? This is not suitable for me at least… If I want to PP the data, I generally like to have at least 30min if I have no fix due to nearest CORS about 50km away. Although I could have a shorter baseline to PP if I had a base onsite or nearby with known coordinates. I could also use one if the RTN bases to PP with as it’s a lot closer, about 30km but I need longer observation times if I’m just longing a static position due to a no f…
