Have a RS2+ on v30 with an iOT sim card (not static IP). Is there a way to see the currently assigned IP address with “Emlid Flow”? I can’t seem to find it.
Once I have this IP, can the emlid be reached through the internet? The emlid will be placed as a base station in a remote location, thus the SIM card. Need the ability to access it remotely.
Hi @jheupel,
You can only check the IP address of Reach in the Wi-Fi network in Emlid Flow, the IP address provided by the SIM card isn’t available in the app.
Provided public IP address should help you to access the device remotely. Please don’t forget to turn off the setting that prevents Reach from being accessed outside the local network:
THANKS!
Johannes
