I am interested to hear peoples experiance of operating the RS2 with NTRIP correction (eg Leica SmartNet).
What reliable repeatable accuracy do you achieve using a paid correction subscription, and how does it stack up against other equipment eg Trimble R8, leica GS18 etc.
The reason I ask is - I already use a RS+ as a base for PPK image tagging. I also currently hire in an R8 or GS18 or equivalent for capturing points such as GCP targets or base locations. Quite often I need XYZ coordinates immediately for surveying in a LiDAR base station so there is not really time for post processing.
I am just at the point where I need to hire in a GPS rover almost weekly. I am also looking to get the RS2 for L1/L2 to with with the m2…
So the question is… with NTRIP correction, is the RS2 accurate enough to replace my need to hire in any other GPS rover etc.
I dont expect it to as accurate, but if it is almost nearly as good then it seems like a sensible solution…
What are your real world experiences with the RS2 with NTRIP correction.
Thanks
