Tried multiple times, multiple routers, multiple restarts.
The unit is an RS+.
Can the dev versions be flashed using the pc or do you have any other suggestions?
Thanks.
There’s no easy way to do what you’re asking to do. But I’m pretty sure we’ll come up with another solution.
Could you please tell what version you’re updating from?
In order to understand why the update fails we might need to get a little more information. Could you please share the Full System Report after you see this issue? Just try updating one more time and then edit the address bar to contain only the IP of your Reach by erasing the trailing “:5000”. This report would be of great help.
It seems like the issues with the Internet connection might have caused the updating failure. The unit couldn’t download the image straight away. However, once the connection became stable the next day, Reach RS+ successfully updated.
Hello, today I tried to update RS2 from 2.23.6 to 2.23.9 but it “Failed to perform update” so then I used the reflash tool to reset the device to factory defaults and it was a success, so now I have stable 2.23.7 and still can’t update to 2.23.9… it is annoying.
Is it possible to download the image of 2.23.9 for rs2 and do it using a reflashing tool?
