I have a RS2 that not powers on.
Has the powern on also a reset function for the device (longer press)?
when i connect to a charge it shows loading then charging and full charge.
regards
regards
Hi Andreas,
Could you clarify if the device has behaved in such a way from scratch?
What’s the LED sequence once you press the power button?
I did Test it. Everything was ok.
I did sind it to a Customer.
On it don’t goes on.
The.funny thing is if he Connects Power to,usb the device Starts.
Battery Shows 100 % . If he removed usb Power it Turns off.
Could it be something with the external power setting? But then that for the bottom connecter only ,Right?
Hi Andreas,
Would it be possible for you to generate the Full System Report on the unit and send it to me in PM?
Hi Andreas,
We will replace the unit. Sorry for the inconvenience.
thank you very much!
