After flashing updating to 2.18.0, rndis didn’t work when I connected from Linux. When I reverted to 2.16.2 by flashing the firmware, it works as expected.
Can you describe your actions, please?
With version 2.16.2, the network interfaces showed up automatically when I plugged the USB into a laptop running Ubuntu 18.04. I was able to ping and ssh to 192.168.2.15 without a problem. After updating with the OTA 2.18.0 release and rebooting the Edison, I was no longer able to see the network interfaces and could not ping 192.168.2.15. I reflashed the firmware from Ubuntu using 2.16.2 and the network interfaces appeared again.
Rob, do you have RS or original Reach?
Thanks for the clarification, @rrr6399.
I’ll try to reproduce the issue and let you know about the result.
