Regarding bluetooth devices…Where do you get this error?
Regarding config tab…
Try 2 things:
Clear browser cache. After update the page usually changes, but most browsers refuse to recognise that immediately. Easiest way in firefox - Open Dev tools, go to dev tools settings(a gear icon), go down until you see Advanced settings and set “disable cache”. Try refreshing
The Bluetooth Error is from Levebure NTRIP app, one one device (android 5) i could apir, but then the apps (Levebure, Bluetooth GPS) would not connect.
From and android 4 device I could not pair at all, even though the reach shows up in the Bluetooth scan and ReachView has even listed the Tablet as paired.
Regarding the refreshing of the config page:
Clearing the cache didn’t immidiatly work, but repeated rebooting worked at some point.
I have the feeling this is linked tot the Bluetooth Issue, since it occured twice after I tried scannign Bluetooth devices from ReachView setting (gear-symbol) page.
Could I think it migth have to do with config templates I created using a previous version of ReachView. I will delete those and create them new.
This sounds like what I’ve been experiencing on Note 4 as well as some other devices including a Topcon FC-500 data collector. Reachview actually shows that Topcon FC-500 is paired but the device doesn’t indicate or show the Reach board. Some devices show the Reach, others don’t.
No, I haven’t. Like I said, some work, some don’t. Currently I use a Lenovo Yoga tablet. It seems to work alright, sometimes drops out but in general, pretty good.
We don’t experience this anymore…
one thing thats happening is that we cannot pair if there is no solution yet (single solution), when starting up or very bad sat-view
Interesting. I’ve tried to connect my Samsung S7, Nexus 7 (both Android 6.0) and HTC One M8 (Android 4.4.2) to Reach over bluetooth and none of my devices even register as being discoverable through reachview. Do you have any suggestions?
It only shows up as pared in rechview, but it doesnt say its connected on phone og reach.
But when opening up bluetooth gps app and push connect, it all works.
the issue I’m having is that in reachview, when I scan for a bluetooth device to connect to, none show up as being discoverable (much less paired)…even though I have 3 devices sitting right next to it that have bluetooth enabled. Are none of my devices compatible with reach? If that’s the case, is it a hardware or software issue that makes them incompatible?
Hello everybody. (and sorry for my poor english, i’m doing my best)
My aim is to use the reach with AgriBus-NAVI or any tractor guidance.
I’m trying to connect my Reach Rover to a Samsung Galaxy E (Android 4.4) via bluetooth.
But the tablet is not seeing it. (it can see a computer, and the ipad, but not the reach)
The reach rover is seeing the tablet, but nothing is hapening when i’m sending a pair request.
I was able to pair the Reach Rover to an ipad, but it’s no use…
Any information about the android version i need for my future tablet ? (or a windows one ?)
Thank you
I will also confirm that my bluetooth troubles associated with the Reachview 1.2 mentioned earlier in this thread have been taken care of with the new Reachview 2.
