Can somebody from Emlid comment on the removal of root access?
Seems that now we only have user level access. Is this by design? Is this something specific to the dev edition or is this how the updates will come out from now?
Why isn’t this mentioned in the release notes? This is breaking functionality for us and possibly others.
Few additional bug reports for the dev version 2.21.1 .
“RTK settings” don’t persist. I set “Elevation mask angle”, “GNSS select”, etc. Power cycle the unit and the values are back to defaults.
The BEIDOU satelites are shown as B[x] in the bar area of the “Status” page. In previous version it was C[x] and it is also “C” in the documentation. Is this intentional change?
Seems to be an issue with base sending Beidou and/or QZSS messages.
I tried with base(RS)-rover(RS+) config over ntrip and both RTK2GO and Youcors show the same issue. Data seems to choke up or not beeing transferd properly and at rover end the grey bars doesnt show up but base data i recived every now and then (10-20sec interval)
2.21.1 on both units
the same happens to me using the RS2 with ntrip , and via Lora I notice the age of differential very high, in RS + it keeps under the age of differential
I’ve been using a couple of original reach rtk units, upgraded to 2.18 and got caught out by the 2.18 3DR radio issue.
Tried upgrading to 2.21.1 to see if it was resolved but doesn’t appear to be. Can’t say if it exactly the same cause as setting UART serial output in Base Mode sometimes hangs (spinning busy circle doesn’t go away). After rebooting the serial output setting seems to have stuck but I cannot receive corrections at the rover.
I also encounter the zero AR and GNSS Select under RTK settings are lost after rebooting.
I re-flashed the unit and don’t have this issue any more. So this is something related to an upgrade path from the stable version to the new version. Perhaps the format of the settings in the new version is not backward compatible.
Before re-flashing, in the upgraded version, it was happening every time. Try a QA flow where you start with a stable version, set RTK properties, then upgrade and try to work with it.
This is actually pretty long gone. Since the beginning of 2018. It’d be great if you could recall what version of RV were you using at the time? Either way, we’re sorry this led to some frustration. If this is needed for your work, we’ll bring it back.
Several problems with the dev version. 2.21.2 for Reach RS antennas.
•By turning them on in client mode, they keep looking for a new update. The status does not change and shows the message “Fetching metadata version”. I have to turn off and on several times to get the message “You are updated”. Reachview app responds very slowly.
•The problem of unstable input corrections has returned.
Gray bars appear and disappear suddenly.
It is very difficult to achieve the “fix” over very short distances.
•When you are in reachview (no matter client mode or hotspot mode) you change to another app and return to it the message “No connection” appears.
In previous versions you could go from reachview to another app and return without problem the connection was restored immediately.
The problem is the same with the app and with the google browser.
Could you please share Full System Report with us?
Thanks for the report. There was a lot of work underneath ReachView in this release and I’m sorry that you have experienced these issues. We’ll try to resolve them as fast as we can.
@george.staroselskiy
Can you verify that there is an issue with the Antenna Height in Base mode (on the Base)? From what I can see, it gets completely ignored resulting in weird altitude readings on the rover
