Merry Christmas and Happy New Year! We have just one small new feature we want to push before we go on a small break - phase measurement based heading.
Features
Delta-phase positioning smoothing for better single positioning and heading. This comes in handy during stakeout, as we now provide precise heading even in single mode.
Fixes
ReachView now supports working with NTRIP casters that don’t send SNR values. There will be no grey bars to show on the chart, but apart from that it works as usual.
This is a little something to keep you guys occupied during the holidays
We’re always happy to hear some feedback, so don’t hesitate to share if you have some!
I am testing version 2.17.0 and in the stakeout I do not see the deltas. the ideal is to see two values of direction either N-S and E-O is very difficult stakeout with only one direction and with the graphical arrow
Dev series (Odd numbers) is a continue from the last stabel version (stable is even numbers).
So yes, DEV 2.17 should contain everything from the stabel 2.16.2. Except from the bugs i guess, BUT could have new ones as the DEV might introduce newer features for testing
It’s pretty typical in most survey gear i have used to report in terms of northing and easting (Y,X). Negative values reflect the opposite directions. More relative to the coordinates and much cleaner interface that way.
Have a graphic on the screen, with an arrow that points in the direction of the sun (and/or moon) and an arrow that shows the direction that you need to go. Similar to an Automatic Direction Finder in an aircraft, with the beacon being the sun (or moon, or both) and an arrow (or bug) of where you need to go. And then you don’t need to worry about keeping the orientation of the Emlid or phone and know roughly where the sun is.
@egor.fedorov, could you give a link or (brief) explanation on the theory behind “Delta-phase positioning smoothing”? Is this the same as what is sometimes called Carrier Smoothed-Code?
