When using ReachView Is there a way of entering a decimal point or other characters in the a name field during a survey, or is there a free text field or likely to be one added at some point, or does anybody have a simple remedy / option that I can utilise for the purpose of adding attributes to a survey point?
I can’t answer the first question, however, you could make a search&replace character or phrase when doing the survey, and “process” that when coming back. Workaround, with some extra work, but it would work.
At the moment, you can’t add decimal points or other special characters in the Name field of a project or a point. However, you can add them in the “Comment” field of the project.
We’re planning to add different attributes to the ReachView App in the future. I’ll keep you posted
Thanks @wizprod but I’m trying to avoid as many keystroke errors as possible which I why I wanted to avoid lookup / replace and other rules during processing.
