Hey everyone!
The first update for the app’s open Beta! Version 4.1 Beta is waiting for you in the Play Store.
We continuously improve app features and fix found issues, and your feedback improves this process drastically. Please, continue to report all problems, crashes, glitches, confusing things. Your help is extremely important!
And here is the full changelog for the update:
Norway vertical datum EPSG:5941(NN2000 height) became available, unlocking a bunch of compound CRSs.
Added vertical datums
- EPSG:5942(ETRS89 + NN2000 height)
- EPSG:5945(ETRS89 / NTM zone 5 + NN2000 height)
- EPSG:5946(ETRS89 / NTM zone 6 + NN2000 height)
- EPSG:5947(ETRS89 / NTM zone 7 + NN2000 height)
- EPSG:5948(ETRS89 / NTM zone 8 + NN2000 height)
- EPSG:5949(ETRS89 / NTM zone 9 + NN2000 height)
- EPSG:5950(ETRS89 / NTM zone 10 + NN2000 height)
- EPSG:5951(ETRS89 / NTM zone 11 + NN2000 height)
- EPSG:5952(ETRS89 / NTM zone 12 + NN2000 height)
- EPSG:5953(ETRS89 / NTM zone 13 + NN2000 height)
- EPSG:5954(ETRS89 / NTM zone 14 + NN2000 height)
- EPSG:5955(ETRS89 / NTM zone 15 + NN2000 height)
- EPSG:5956(ETRS89 / NTM zone 16 + NN2000 height)
- EPSG:5957(ETRS89 / NTM zone 17 + NN2000 height)
- EPSG:5958(ETRS89 / NTM zone 18 + NN2000 height)
- EPSG:5959(ETRS89 / NTM zone 19 + NN2000 height)
- EPSG:5960(ETRS89 / NTM zone 20 + NN2000 height)
- EPSG:5961(ETRS89 / NTM zone 21 + NN2000 height)
- EPSG:5962(ETRS89 / NTM zone 22 + NN2000 height)
- EPSG:5963(ETRS89 / NTM zone 23 + NN2000 height)
- EPSG:5964(ETRS89 / NTM zone 24 + NN2000 height)
- EPSG:5965(ETRS89 / NTM zone 25 + NN2000 height)
- EPSG:5966(ETRS89 / NTM zone 26 + NN2000 height)
- EPSG:5967(ETRS89 / NTM zone 27 + NN2000 height)
- EPSG:5968(ETRS89 / NTM zone 28 + NN2000 height)
- EPSG:5969(ETRS89 / NTM zone 29 + NN2000 height)
- EPSG:5970(ETRS89 / NTM zone 30 + NN2000 height)
- EPSG:5971(ETRS89 / UTM zone 31 + NN2000 height)
- EPSG:5972(ETRS89 / UTM zone 32 + NN2000 height)
- EPSG:5973(ETRS89 / UTM zone 33 + NN2000 height)
- EPSG:5974(ETRS89 / UTM zone 34 + NN2000 height)
- EPSG:5975(ETRS89 / UTM zone 35 + NN2000 height)
- EPSG:5976(ETRS89 / UTM zone 36 + NN2000 height)
Broaden ranges of available vertical datums for multiple horizontal CRSs.
Affected vertical datums
- EPSG:5941(CGVD28 height)
- EPSG:6647(CGVD2013(CGG2013) height)
- EPSG:9245(CGVD2013(CGG2013a) height)
- EPSG:5720(NGF-IGN69 height)
- IGNF:IGN69(NGF-IGN 1969)
- EPSG:5613(RH2000 height)
- EPSG:8266(GVR2000 height)
- EPSG:8267(GVR2016 height)
- EPSG:5711(AHD height)
- EPSG:5703(NAVD88 height)
- EPSG:6357(NAVD88 depth)
- EPSG:4440(NZVD2009 height)
- EPSG:7839(NZVD2016 height)
- EPSG:8089(ISH2004 height)
When you create an NTRIP profile, you will automatically receive a list of mount points provided by your caster.
Now, on the third tab, you can modify existing NTRIP profiles and create new ones even if the receiver is not connected.
Automatic mount points loading is not available here yet! You will be able to load them only through Settings while a receiver is connected.
We’ll improve this feature in future updates.
Now the third tab has been renamed to “Profile”.
Added “FIX only” setting that allows point collection only with FIX solution.
If the rover icon is not shown on the map, the “Follow” button now will be disabled as well.
Updated the connected device’s menu by renaming Settings into ReachView 2. Such naming should make clear what settings we refer to in the different parts of the app.
Fixed a bug that might have caused an appearance of negative zero coordinates in the point info and the collector.
Fix the hint for the Night mode switch on the Settings screen. Text now will be relevant for a connected receiver – we shouldn’t promise muted sound for non-RS2 devices.
Fixed some views that were ignoring the Android system Back button.
Since the previous coordinate system for the demo project required to download additional data, we replaced it with a similar one.
Selecting two coordinate systems from the list simultaneously could lead to incorrect behavior. This has been fixed.
Fixed potential app crashes that may be caused by CSV import. Unfortunately, we can no longer guarantee the compatibility with the ES File Explorer app, whose way of opening files differs from what we expect.
Add Russian and Spanish translations for more strings.
Minor visual updates.
Various fixes to ensure app stability.
Thank you for your time and your valuable feedback!
