sorry for the new topic but I want to know if it is possible to post a short tutorial about the wifi config
I try to explain my problem
I config in the correct way my reach with the network of my samsung smartphone and using Internet connection of my mobile phone everything works perfectly (get rtk fix using NTRIP correction from GNSS network of University )
Now I would like to connect using usb cable my device to my desktop at home and config the unit with my home wifi network (my idea is to create a base station with the antenna on top of my roof) but … I’m not able to do this
You wanna check with your ntrip service,if they output error code when service is down or if error is given when VRS is not able to be created at this point or place.
I do not use NTRIP, but for what it is worth, I would say that if you are receiving the correction behind the router, no change is necessary to your router. If you were casting NTRIP from home and receiving somewhere out on the internet, then yes, you would need to open a port on your router for that.
solve the problem …
The solution VRS is not albe to fix instead if I select the Nearest NRT I didn’t receive error message (also if the solution is still single but maybe tihis is related to the lenght of the basline)
After little caal with the provider of RTK correction I discovered that the software that manage the station (Spidernet by Leica Geosystem) has a setting to limit the distance to receive the ntrip correction at 100km from bases station I asked to change the limit to 150 km and voilĂ I was able to fix
I know that this situation isn’t “real” but it is just a test form my reach and the result I think it very interesting (maybe we can built a GNNS network lowcost…)
