I have a Reach RS2 receiver that I control with a Samsung S5 Android 6 device and it works very well. I had to replace the Samsung Android 6 device with another device with a higher energy storage capacity because I risked running out of battery when I was in the field, so I found an OukiTel WP5 Pro device with Android 10.
The problem is that I can’t connect this device to Reach RS2 I get the message as “Connected, no internet”.
With the old device I manage to connect to Reach RS2, in the Wi-Fi menu you can see the hotspot (name: “pt.reach”) which has the status “not avalible”, hotspot created by the device I would like to connect with, namely OukiTel WR 5 Pro.
If necessary, I can also send you the detailed report generated by Reach RS2.
Please, how can i solve this problem?
Thank you very much, let’s hear only good.
Reach indeed doesn’t provide an Internet connection in hotspot mode unless you have a SIM-card inserted. However, can you access the device in ReachView in that case?
