Hi there,
Yesterday I’ve updated my Reach RS+ from reach view 2.14 to 2.16.2.
After that I put it outside for testing.
During the test the Reach RS+ suddenly stopped working. At the beginning of the test the battery was 71%. The test stopped after +/- 45 min. Of course I ‘tried’ to charge the RS+ but it won’t start anymore. Also tried to hold the power button for 15 seconds etc… No led’s are coming up…
hmmm… sounds quiet similar to my problem.
I’ve send them an email yesterday already but there out of office until the 9th and I need the unit this friday (the 4th)…
Before flashing it, when was it used last and when was it charged last?
After flashing and starting your test, you say is died after 45 min. Did you immediately notice that or did some time pass between when it died and when you tried to charge it?
When you tried to charge it, how long did you leave it plugged in for?
Did you try plugging into a different power source?
Did you try using a different USB cable?
If you put your ear up to it while trying to charge, can you hear any quiet frequencies emmiting from RS+?
It was used for about 1 hr before flashing it. Last time it was charged was in November '18.
I’ve noticed it directly because I was connected with the Reachview to check the fix status and process…
In the beginning it didn’t charge at all. Just after a few tries the orange LED started blinking. I’ve charged it over night (8Hrs). The next morning the orange LED still was blinking. After I took it off the charger the LED stopped blinking and the RS+ wasn’t able to start (no leds responding). Also if I put it back on the charger the LEDS shows off…
Yes, various power courses, various adapters, various computer USB ports, various cables…
Yes
No… silence…
Besides the post that was linked into this thread, it seems that there are more recent posts with power / battery issues… @timmyd, you might take a glimpse at this one too…
My base unit did charge up and as soon as I know for sure I won’t use them for a couple of days, I am going to put both units out and let them run continuously as @bide suggest and log them both to see if my Base unit powers off much sooner. i will report back when ever I get a chance to do that. I have no idea what to expect but time will tell. I hope the battery is good on the Base
