Not to pile on, but I’m actually having the same problem (blinking green LED) on both our Reach RS+ units.
For what it’s worth, we hadn’t used them for some time and yesterday I broke them out to update them. I downloaded and installed 2.22.6 (I think… whichever one was available yesterday afternoon) then tested them out after that. This morning, I turned them on and they’re both blinking green with no way to connect to them.
Any suggestions? I can do a firmware flash if need be, but I wasn’t sure if there was another option.
I believe that I was updating from Version 2.18.[something]. It had been a bit since we’d needed the units so they hadn’t been updated. This is the first time that I’ve encountered this issue.
the other LEDs are solid, the green LED is never solid.
The reach viewer cannot be entered because the green led is never solid, so I cannot send the report. Before I only had that problem with the base, now my rover and base have the same problem.
I updated to v2.22.6 as I had several start ups where the green light turned solid green after starting so I could access the software. It still worked after re-booting and I set it up for a survey the next day (yesterday). Sadly, the same issue returned and I could not carry out the survey. I tried throughout the day but the green light kept blinking. I set it up on my window sill this morning and it started correctly. Very frustrating.
I’m afraid that I’m unable to connect to either of our RS+ units through ReachView. Unless there’s another way to access the full system report, I’m going to be unable to get it.
Regarding the status lights: They’re on and solid. The green one is blinking.
I saw your announcement of the dev release 2.23.9 that lists what I interpret is a solution to this particular problem. Would you recommend that I reflash the firmware and then get this update?
Hi! The v2.22.7 is already on the way and is going to be released today or tomorrow, so I suggest waiting for it. Furthermore, if I understand correctly the ReachView is unaccessible for you now and there’s no easy way to install v2.23.9 right now as it requires the interaction with the ReachView app.
