Hi there, I’ve been looking at getting set up with RTK correction for drainage in our fields. I plan on pairing Reach RS+ with BrianTee’s Opengrade onto my microsoft surface pro. Will I be able to pair my rs+ rover to my surface pro via bluetooth? and will OpenGrade be able to read the rs+ correction?
I would encourage you to purchase the M2 or the RS2 over the M+ or RS+. For drainage work the little upfront difference will be well worth it in the long run.
Thank you for your input. As I understand it, the M2 is more reliable because it is multi band?
Yes I realize I’ll have to do some hardware building to get OpenGrade to control the blade height. That’s why I enjoy these forums so much. Very seldom there is something that cannot be solved!
Yes, the data from more bands enables M2 to obtain the fix faster. Also, more data helps with calculating fix solution when the conditions are more demanding. However, single-band receivers are can do the job just fine when provided with a clear sky view with minimum objects deflecting the GPS signal.
