Hi! I have a WiFi network set up with internet connection, but when I start my reach module it always goes into hotspot mode (blinking green and white). I then have to log onto the reach network and manually go to Wi-Fi/Bluetooth, click the network name and then ‘connect’. This procedure always works but it’s a bit time consuming, does anyone know of a solution?
I’m using ReachView 2.7.1 and as far as I know this problem did occur on 2.6.x and previous.
I’m just speculating. It seems to me that if Reach is turned off before logs have processed, that the boot process is unpredictable. Once the files are processed, it seems to boot OK for me. But, have not tested enough to know for sure. Just something to look at …
Same problem here. One reach (which connects to powered USB) always connects to wifi. The other one (which connects to computer via USB and we use this USB to read IMU) often doesn’t connect to wifi. It creates a hotspot. After manually connecting to wifi it works. But I would say 80% of the cases it creates a hotspot.
i did try ap_scan=1 long times ago.
i am no linux expert …
Hi i have insert
ap_scan=1
in wpa_supplicant.conf. No i think reach works better…!
When using IBSS or AP mode, ap_scan=2 mode can force the new network to becreated immediately regardless of scan results. ap_scan=1 mode will first tryto scan for existing networks and only if no matches with the enabled networks are found, a new IBSS or AP mode network is created.
