Hi. I have been using a reach rtk module with a Sony RX100 without problems for more than a year now.
I also have a Samsung NX 1000 camera, but it does not work with reach rtk module at shutter speeds of 1/200 and above.
Does anyone know if Reach M2 is compatible with Samsung NX1000 camera at shutter speeds of 1/800 or 1/1000?
It would be great if I could use the Samsung camera with its larger APS-C sensor.
TB_RTK
May 29, 2020, 5:58am
#2
I think its the camera. I have the nx100 which has a limit at 1/200 I think. Above this speed it doesn’t produce a trigger signal. I of course, hacked it to overcome the problem. Nothing Reach can do about it
YAYY
[aircat]
Just dropping a bunch of pictures here, they speak for them selfs i think.
But so far i hooked up 3dr radios and succesfully connected to mission planer and done the mandatory things for the radio and the calibration.
The next big reveal is the camera. I got a couple of the Samsung NX100 cheap from ebay along with the prime 30mm lense which is the better one in that production line. This camera had all i was looking for and it was cheap (90$) on Ebay.
It had jackplug for trigg…
Thanks for your answer @TB_RTK , I´ll check your post!
system
(system)
closed
September 6, 2020, 5:36pm
#4
