Reach Firmware 31 Beta 3 is out
I see. RS+ base and RS2 rover won’t work correctly because RS2 needs multi-band corrections. RS+ can’t provide them. But you may use RS2 base with RS+ rover. Here’s a bit more information about this setup:
Thank you… We’ll start there.
Of all the reading up on this I’ve been doing, I guess the directions would have been where I should have started…
Hello everyone! 31 Beta 3 is out for all devices!
Fixes:
  • Fixed some cases when Reach falls to searching for Wi-Fi mode and does not go to hotspot mode
Changes:
  • Now all multi-band devices can work only in kinematic GNSS mode
"Changes:
Now all multi-band devices can work only in kinematic GNSS mode"
Does this mean that Static mode is no longer available?
Hi @mark1st.john,
Yes, we removed the Static option for the Positioning mode in the GNSS settings of multi-band receivers. It will use the Kinematic option as a default. It’ll not affect the solution calculation on your receiver.
Hi everyone,
The issue when the age of differential grew up uncontrollably and didn’t recover on 31 Beta is fixed in the stable 31 Firmware.
Please update your receivers if you faced this issue described below.
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
