Right, I mean that post. We were checking the issues with the NTRIP connection mainly.
Regarding the issue with the hotspot, when has it started? With 29 Beta 1 update particularly? Have you tried to connect via a different device to understand if it works the same way?
The receiver hotspot issue started with 29 beta 1. I have tried two different phones but both were on Android. I am not sure if this is absolute or not but I can sometimes connect after forgetting the network and then re-authenticating. This has been a trick that Iāve used for a long time but it continues to happen now. Here is what Iām getting in the correction input settings.
So it seems that it will stay fixed for about 3 to 5 minutes and then it went back to single. I checked my internet connection and my Wi-Fi connection to the Rover and everything looks okay. Ntrip says itās connected but no fix.
I reset the settings to default on the RS2, went back through configuration and achieved a fix. I will test it again in a little while and hopefully it sticks.
Thank you very much. I think I have isolated my Roverās problem with fixing after the rollback was due to the hotspot on my phone. I connected it to a different hotspot today and it is getting a fix fairly quickly. It does seem like I am having to forget and reauthenticate the Wi-Fi connection to the receiver whether it be through my hotspot or to the receiver hotspot.
Firmware 29 Beta 1 knocked my RS2 out like LL Cool J.
It was the first time I had to use an external computer to restore a previous firmware.
Battery was 75%, no power outages, etc.
Any ideas what could have caused this?
The unit entered a perpetual boot cycle. I left it for one hour, had my good old sledgehammer with me when coming back, but then found a thread dealing with resetting the device.
Weāve found an issue with the correct mount point fetching. This explains why you could get FIX when entering the mount point manually. Weāll fix this in the future release. Thanks for drawing our attention to it!
Regarding the intermitted work of the hotspot, itās a bit of a mystery now as we couldnāt repeat it so far. But weāll try to check this with more devices.
Horrible day today and off the bat I will say that I think a lot of it has to do with Verizonās crubling network in our area. I had no more than 2 bars all day on 4G or 5G and while the NTRIP would login it kept telling me it was waiting on corrections. There are several things that I have had to do on V28.4 since rolling back that are all related to connectivity in some manner. I am having to forget and reauthenticate with networks, kill the Reachview 3 app and reboot the RS2 in order to get it to change from the Reach hotspot to my mobile hotspot. II can tell it is on the mobile hotspot because the Reach hotspot disappears as an option but it is taking at least 10 times every session to get it to show up as an available receiver. Once it finally decides to show up it operates as normal, NTRIP looks good but the receiver stays in single.
If I can get on the internet with another device connected to the mobile hotspot shouldnāt that be enough bandwidth to stream corrections? It feels like Reachview has some authentication and network switching issues.
" * Added point markers into the RINEX log when collecting data with ReachView 3 - if you have RINEX logging enabled, collection start/stop events will be saved into the RINEX log"
I am wondering if we use this option, do we still need the CSV file from ReachView 3 to do post-processing in Emlid Studio?
It would be nice if the UTM coordinates are supported in Emlid Studio directly.
We added this mainly for the users working in the 3d-party software who could use the files from Reach. For Emlid Studio, you need to export the file from ReachView 3 to process it in Stop & Go.
