If raw logging is set to RINEX, the raw UBX log is not recorded
Configured the output of the last valid heading (COG) in NMEA VTG and RMC messages when there is no movement
Added ability to downgrade from Beta release to the latest stable release. For example, if you want to revert to the stable, you can downgrade the firmware from 28 Beta 1 to 27.1
Made Reach M+/M2 visible for the ReachView3 app or Reach Panel without connecting the antenna and being in the hotspot mode
Removed 230400 baud rate as an option for Serial input/output on Reach RS2/M2
Fixed some issues with interruption of downloading large log files
This a great upgrade. Could you also improve the bluetooth connection performance too? We noticed that sometimes, it is very hard to connect to its Bluetooth, and sometimes the bluetooth connection drops.
oh no, this isn’t good news!
At least provide the choice
Rinex logging is great for quick access to ie a log of gps + glo at 30 seconds. However, providing the UBX offers added security for screw-ups. If you for some reason made some funky settings on the Rinex, your 1 hz all constellations ubx is a lifesaver!
At least the option to record both is needed.
Especially for me now, not being 100% sure if Rinex or Raw in my usecase.
I would have to stay on this version with needing both
Agree! Having the RAW log file and Rinex is really needed (or the idea of a checkbox that allows you to select both). It is really easy to push the delete button if you don’t want the RAW file later. If your Rinex is set for PPP, it’s great to have the all constellation backup if there is an unexpected need to ppk your session in the office (like loss of Lora/cell coverage or difficult sky view conditions).
It sounds reasonable, and I’ve just discussed it with the team. We’ll return the possibility to record the UBX data as a dup for RINEX.
There is a temporary workaround for doing it on 28 Beta 1: just enable the Raw data debug option in the device’s settings before you start logging. UBX data recorded with this option will be heavier, and you will need to re-enable Raw data debug after each reboot, but it’ll work.
+1 for UBX and RINEX. On a few occasions I’ve not been able to PPK P4R data in RedToolbox with the RINEX observations but worked fine with the UBX observations.
This right here. I think this deserves some cudos to the people at Emlid, taking inputs and wishes from users. Of course within some limitation.
This is great
The UBX will be making a comeback, you can be sure
Thanks for being vocal with us! Such strong community is what makes us happy and proud about our products So if anything can make your workflow with Reach receivers easier and more comfortable, don’t hesitate to let us know!
Base coordinates insertion is mostly ruled by the ReachView 3. So the firmware update doesn’t affect it.
In ReachView 3, you can indeed insert only geographic base’s coordinates manually in LLH format. It helps us to wok better with the RTCM3 transmittance. We’re checking how we can allow you to insert your base in different coordinate systems. It’s a bit complicated.
As a workaround, you can go with the flow with Base shift feature. It’s a non-obvious solution, of course, so it’s better to stick with the LLH solution.
