Hi everybody! Having only one issue in both ROVER and BASE. After the update never can boot in the first attempt, I turn on network goes solid and blue after certain time but leds still runing for ever and no solution or even connct to the unit posible so, turn it off and turn it again on and goes through all the process normally. Out of this issue everything works great and better like the loss of solution and recover are really faster (example going under a tree solution lost but leaving recovers sollution fastest than before, tested in the same conditions with previous fiurmware). Thanks to all people working on this equipment.
Hi Guillermo,
What Reach device do you have?
So, does it look like the unit is booting?
Yes but stops at some point. This is solved in new beta 2. Thanks
