It’s that time in the Raspberry release cycle. The Raspberry foundation releases a new Pi and we hound you until the Navio board can run on it.
With USB3 support, H265 at 60 fps and a significant bump in specs, the new Pi is planting it’s foot into Jetson TX’s territory, breathing significant life into Navio2.
Streaming H265 over wifibroadcast? Plugging in a Movidius for a machine-learning flight model? A Realsense camera for top of the line optical flow? Running previously impossible Kalman filters on large datasets? All possible.
I understand the changes required are:
Port the RT patched kernel to RPi4
Port the RCIO driver
Make sure Ardupilot stack is still working after cross-compiling on the new CPU
Misc tweaks and QoL
Can you guys provide a timeline? Any way to follow development, maybe lend a hand?
Yes, im also very interested in this! A little time ago i asked the support if there will be a Nanopi M4 support. They told me ( and of corse i understand this) that it will not be any. So please make rpi 4 support happen!
Thanks!
Hello,
Can you explain to me how your workflow is?
Your repo for the image builder changed last time in February this year. Same thing with the kernel. But you said: you’re working on it.
I also made an issue because your image builder isn’t a fork of the original Raspbian as it should be.
I was wondering if there was an update on the image for the raspberry 4 by Emlid? I was also wondering if there was another Image we could use mean time?
well, if i purchase the navio2 board for my raspberry pi 4 will the existing image at least work so i can learn to use ardupilot (actually ardurove - i will use it for my rover) and ROS ? i want to replace my px4.
Even though Raspberry Pi 4 and Navio2 are compatible in terms of hardware installation, there is no appropriate software for them to work properly together yet.
So, at the moment, it is impossible to configure Navio2 with Raspberry Pi 4 for an effective working setup.
